Number Format not reflected in Labelling (DATE field)
3288
06-30-2021 08:37 AM
BrianBulla
Honored Contributor
Just wondering if you set the Number Format for a specific field, should that also be reflected in the Labeling of that field in the map?
For example, I have the Number Format for a DATE field set to this:
But in my map it just shows the default format.  In the table it is showing the proper format though.  Is this a glich, or just how it works??
WendyHarrison
ah - vbscript, jscript and python will respect the field formatting that is set.  You're using Arcade (the default label expression language in Pro), which pulls the raw feature and then gets the field value - it doesn't go through the field formatting.  This method is better in the long term as it is more portable for the expressions.
If you want to switch to a different language you can do that on the Label Class pane on the expression tab - see the help topic referenced above.
WendyHarrison
Hi Brian,
For labeling you'll need to set up the formatting in the label expression.
https://pro.arcgis.com/en/pro-app/latest/help/mapping/text/specify-text-for-labels.htm
at the end of this topic are links out to the languages Pro supports
thanks
Wendy
BrianBulla
Honored Contributor
Yes, I understand, but why is the label not taking on the format that you apply to the field?  Seems easier to just set it in one place than to have to go to multiple different places to show the same formatting.
WendyHarrison
BrianBulla
Honored Contributor
That's great.  Thanks for the explanation of what is going on.  Is there a way to set the default language so I don't have to go in and manually change it for each layer?  Perhaps a system setting that overrides everything??
WendyHarrison
We don't have that option at the moment.  There's an idea that you can vote up and add comments to.  I'll post below
https://community.esri.com/t5/arcgis-pro-ideas/choose-your-default-scripting-language/idi-p/1031561
