notebooks slow in ArcGIS pro, Desktop, Analysis
1821
12-15-2021 09:50 AM
DavidAnderson_1701
Running Arcgis pro 2.8.
I've noticed that notebooks running inside a project are substantially slower than running the same code as a stand alone Jupyter notebook.  So slow, that working in a notebook in a project is not possible because after the first couple of cells execute, I get the [*] and the notebook is locked up until exiting the project.  Even something as basic as looking for help with arcpy.mp.ArcGISProject? won't run to completion.
Has anybody else seen this behavior and if so, how to fix.
Tags (3)
DanPatterson
MVP Esteemed Contributor
You might have to scroll through the open and/or closed "Issues" on github
Esri/arcgis-python-api: Documentation and samples for ArcGIS API for Python (github.com)
or log an Issue there to get directly to the source developers
... sort of retired...
