has anyone else had issues after updating ArcGIS Pro to the latest version (2.8.3) with Notebooks?
this code use to work (ive simplified it but its as below)
xxM = gis.content.get("54e........")
xxLive = xxM.layers[12]
NewxxLive = xxLive.query(where="OBJECTID = 1")
i now get this error:
Exception Traceback (most recent call last)
In [21]:
Line 50: NewxxLive = xxLive.query(where="OBJECTID = 1")
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\features\layer.py, in query:
Line 1547: record_count = self._query(url, params, raw=as_raw)
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\features\layer.py, in _query:
Line 2563: raise queryException
Line 2533: postdata=params, token=self._token)
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\gis\_impl\_con\_connection.py, in post:
Line 720: force_bytes=kwargs.pop('force_bytes', False))
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\gis\_impl\_con\_connection.py, in _handle_response:
Line 514: self._handle_json_error(data['error'], errorcode)
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\gis\_impl\_con\_connection.py, in _handle_json_error:
Line 536: raise Exception(errormessage)
Exception: Invalid Token
(Error Code: 498)
but whats really odd is that i can list all the fields that are in that layer
for f in xxLive.properties.fields:
print(f['name'])
what has this new version done...
Solved! Go to Solution.
I can't help because the line numbers in the trackback don't line up with my version (1.9.1). You could try updating to the latest version, or update ArcGIS Pro to 2.9 when it comes out of beta final very soon, (it uses 1.9.1)
are you using arcgis 1.9.1?
Hi @DanPatterson since the update its using arcgis 1.8.5 i think it was 1.8.4 before the update...
Stu
Thanks @DanPatterson I’ll keep trying
upgraded to 2.9 last night and it seems to be working again 🙂
glad it worked out
