New Task: Creates File Geodatabase but can't see it
741
02-26-2019 03:32 PM
JoeBorgione
ArcGIS Pro 2.3: first time creating a task:  It's only two steps.  First step runs the Create File Geodatabase gp tool.  This is an optional step.  Second step runs the Feature Class to Feature Class gp tool.  However, if I navigate to the directory where my new fgdb was just created, I don't see the the new fgdb.  I can exit out of the task, start it again, skip the create fgdb step, and then I can see that fgdb.
How to I get the second task to 'see' the new file geodatabase I just created in the first step?
That should just about do it....
DanPatterson_Retired
right-click on the folder name in the tree and select Refresh.  If it is like anything else, like creating a new featureclass in a gdb, the name of whatever doesn't showup automagically.  It is like a 'Refresh' is gone
Refresh a location's content—ArcGIS Pro | ArcGIS Desktop
But if you use arcpy.mp and 'CURRENT' apparently life is good
Migrating from arcpy.mapping to ArcGIS Pro—ArcPy | ArcGIS Desktop
but I don't use it, and I don't know if it applies to this sort of thing... but just the mapping stuff, but an FYI in case you have that in mind at some point
or try saving the project
ArcGISProject—ArcPy | ArcGIS Desktop
JoeBorgione
Yepper... That did it.
