Network restriction options in ArcPro
2054
05-19-2019 03:29 AM
Nicole_Ueberschär
After finding out that I cannot create a new network dataset from scratch in ArcPro (which is a real bummer!) I created one in ArcCatalog, created a template, and created a new dataset from this template (to simulate the workflow for customers of us). Now in the original network dataset I have the option that I can add restrictions but not in the one created from the template.
Why is that and how can I solve this? The data structure is for both networks the same with a feature dataset of 5 road classes plus the junctions.
EDIT: I played around a bit and added bus lines and bus stops to the network dataset and changed the group connectivity - and voilà: I have the options available. But maybe someone can tell me what exactly made me not having the options available before?
DanPatterson_Retired
at the bottom
Network attributes—ArcGIS Pro | ArcGIS Desktop
is that what you did to enable the access to the properties and the Travel Attributes?
and from here
Create Network Dataset From Template—ArcGIS Pro | ArcGIS Desktop it says just the schema is created
at the bottom
and from here
Nicole_Ueberschär
So if I need restrictions I would have to add them already in the network I create the template from?
at the bottom
Yes, exactly. The options menu on the restrictions tab is all greyed out.
