Network Dataset Field Script Using Python
1353
02-13-2024 10:31 PM
__JackCharde__
Hi Everyone,
Maybe someone can point me in the right direction. I cannot for the LIFE of me find information on why the Field Script evaluator in ArcGIS Pro 3.2.2 has absolutely no other bits of the UI it used to have in ArcMap. I don't see a function helper list, or a list of available fields.
I know the appropriate use would be wrapping the streets field name in exclamation points, as with field calculator (!<name>!), but why is the Field Script box so bare?
Best,
Jack C
__JackCharde__
Hey Kendall3,
I'm not entirely sure what that has to do with building a road network locally without AGOL or Portal and creating evaluators. Did you mean to reply with that in a different post?
