NetCDF date import into mosaic
1105
05-11-2021 07:36 AM
Anneley_Hadland
Hi, I'm trying to import a few NetCDF datasets into a mosaic dataset, however it's not recognising the timestamp. If I import as a single raster layer or table view it knows what time is associated with the layer, but when importing to the mosaic, it sets all of the Standard Time field to 01/01/1970.
I've tried as a temporary hack just overriding it by parsing the timestamp from the fieldname, but this is then not read correctly by the chart plugin, it reads 2020 as 1995.
Any suggestions as to what might be the problem? Thanks
DrVSSKiran
Please cross-check the options before importing the NetCDF rasters into the mosaic dataset. Enable all the mosaic post-processing options and once data is imported please go to the mosaic dataset properties and set the time properties.
Anneley_Hadland
Hi there, thanks for the reply. I've tried with all the post-processing options and set the time properties. It's still coming up with the same issue however that the time extent is wrong, still stuck on 1970.
