Need help with geocoding addresses
1447
04-01-2025 08:30 AM
MET169pitteduTipre
Hello,
I am working with PHI data (medical records) and would like to geocode the addresses without arcgis online. I am working with ArcGIS pro. Previously with arcmap, one could use the address locator files to geocode street addresses in the US. Due to patient privacy reasons (HIPAA), i am unable to use arcgis online and the credits to geocode addresses. I have found a partial solution using TIGER files of address locators from 2010 onwards. However, the computing time is in days for about 80,000 addresses to be geocoded.
I would like to find out if people have run into these issues and what were the workaround it.
Thanks
BobBooth1
Have a look at this tutorial for a strategy for geocoding with the ArcGIS Online locator while maintaining patient privacy.
https://learn.arcgis.com/en/projects/protect-patient-data-when-geocoding/
BobBooth1
Also, if you are using an old locator it may need to be rebuilt to work well with the version of ArcGIS Pro that you're using.
See this thread:
https://community.esri.com/t5/arcgis-pro-questions/geocoding-taking-a-lot-longer-in-arcpro-3-0/m-p/1...
MET169pitteduTipre
Thanks. I downloaded state locator fiel from TIGER/census and for some reason, arcgis pro does not load that file
BobBooth1
