Need help with field calculator.
2265
7
03-11-2024 09:10 AM
EGardner7
I am trying to use field calculator to move numbers to the front of a value. For example, Apple Dr. 245 to 245 Apple Dr. I have tried a bunch of different python scripts that are AI generated but I can't get it to work. Does anyone know why I could be having issues with this? Here is one script I tried for example:
def move_numbers_to_front(value):
words = value.split()
if len(words) > 1 and words[-1].isnumeric():
return f"{words[-1]} {' '.join(words[:-1])}"
return value
# Usage: move_numbers_to_front(!CableName!)
DanPatterson
MVP Esteemed Contributor
indentation perhaps
a = "Apple Dr. 245"
    return value
move_numbers_to_front(a)
'245 Apple Dr.'
... sort of retired...
EGardner7
Unfortunately that didn't work. Thank you though!
JoshuaBixby
Comments like "that didn't work" aren't helpful.  If there was an error, what exactly was the error, and provide a traceback if one exists.  If there was no error but the results are unexpected, state what you expected and what you got.
DanPatterson
Then you might want to provide the error message.  Perhaps, you have some null values in the field or other issues with the contents of the field
EGardner7
Yes there are null values in the field. How do I get it to ignore those? The error message is: There was a failure during processing, check the Geoprocessing Results window for details.
DanPatterson
perhaps
a = None
    if value is None:
        return
    return value
print(move_numbers_to_front(a))
None
DanPatterson
did it work? or were there other issues?
