Need Help Accessing AI Assistant (Alpha) in ArcGIS Pro
1063
07-25-2025 07:08 AM
Labels (2)
SHAMALAHMED
Hi all,
I’m using ArcGIS Pro 3.5.2 and I’ve heard about the new AI Assistant (alpha). I’d like to use it, but I can’t find any option to enable or access it.
  • Is it available in 3.5.2?
  • Do I need to update or change any settings?
  • How can I get access if it's in preview?
Thanks for any help!
MichaelVolz
Esteemed Contributor
Try this link - https://earlyadopter.esri.com/enter/err/Session_Expired_Server_B/lr/0/?ref=%2Fhome.html%3Fevent%3DCo...
If that does not work or AI Assistant Beta testing is not available I would give ESRI Customer Service/Tech Support a call at 888-377-4575.
MichaelVolz
You need to sign up for this beta version.
SHAMALAHMED
Kindly could you provide the link to sign up?
MichaelVolz
