My Utility Network Analyst toolbar is grayed out
2889
04-19-2021 03:01 AM
MohamadAchour
Hello,
When I pull up my Utility Network Analyst toolbar I cannot use it because it's grayed out.
The checkbox for Customize > Extensions > Utility Network Analyst is also checked.
Why did I have this problem?
Any idea?
DanPatterson
MVP Esteemed Contributor
toolbars usually become enabled when an appropriate layer is selected in the map's table of contents
... sort of retired...
MohamadAchour
That's mean my polyline shape file cannot be executed with the network analyst?
If yes, do you have any solution to make my shapefile appropriate to this task?
Thanks a lot, Sir.
DanPatterson
If you meant Utility network analyst... I don't use it, but I had a quick look at...
Create a utility network—ArcGIS Pro | Documentation
and it seems that there are specific requirements, and I didn't see any mention of "shapefile" as the starting point.
