mulipoint to point
1484
06-29-2021 06:42 AM
SarahHartholt
Is it possible to explode the features of a multipoint feature class into a point feature class using modelbuilder? Or is there a better way for me to create a point layer that stores the start, end and all intersection locations of a roads feature class?
JayantaPoddar
Using Multipart to Singlepart (Data Management)
You may add it to your model as well.
Think Location
DanPatterson
MVP Esteemed Contributor
What is wrong with Feature Vertices to Points?
Where are the multipart features coming from?
... sort of retired...
SarahHartholt
Thanks, I was able to achieve the results I was hoping for using the Feature to Point tool but I bet multipart to single part would work as well.
Feature to Vertices isn't the problem. Using Intersect and changing the output type to point left me with a multipoint feature class. I get an error when I try to merge that with a point feature class.
