Does ArcGIS Pro support voxel layer of irregular grid from netCDF?
1631
06-29-2021 04:45 AM
TomLiu
Currently I am working to import netCDF to ArcGIS Pro to create voxel layer.
Everything works great when importing regular grid which has even spacing on x, y, z.
However, when I try to import netCDF that has irregular grid, for example, even spacing on x, y, but uneven spacing on z, I noticed the voxel layer is created with wrong elevation. I also noticed for regular grid with even spacing on z, the "Exaggeration" of "Elevation" in Layer Properties is always 1, but for irregular grid with uneven spacing on z, the "Exaggeration" of "Elevation" could be 30 or 40, which is greater than 1.
Could you please advise if ArcGIS Pro support voxel layer of irregular grid? If so, what should I do to correct the netCDF file?
Thanks very much.
DanPatterson
MVP Esteemed Contributor
Frequently asked questions—ArcGIS Pro | Documentation
the first suggestion in the FAQ might be appropriate
... sort of retired...
DanPatterson
