Move Toolbar Location
2031
06-19-2018 09:40 AM
JoeBorgione
In ArcGIS Pro, when editing a polygon's vertices, you  are presented with a tool bar that lands along the center of the bottom edge of your map pane.  There is small settings icon on the lower right corner of the tool bar: when clicked you are prompted to 'Select Toolbar Location and Size...'  I can get size to work okay by selecting one of the sized frames but what I'd really like to do is move it off to one side or another.  Is that possible?
That should just about do it....
Robert_LeClair
Esri Esteemed Contributor
Joe - in the Project->Application-Editing options, you can set the toolbar location to be Position - Left, Right or Center.  Is that what you're looking to do?
Robert_LeClair
JoeBorgione
Bullseye.  Thanks Robert!
TamsenWaldron
Thanks but would like the option to drag it where I want.  I think the default shouldn't be smack where I want to work.
