Move simple and network features together
227
04-07-2025 03:04 AM
DirkTillmanns
Hallo,
The area is a simple feature, the line is a network feature. However, if you try to move both features at the same time, only the geometry of the network feature is changed. Pro gives no indication of an error. Any idea?
Best regards
Dirk
CharlesKolbowicz
Hello Dirk,
Same issue here.
After some research and multiple prompts (your case helped me), here is the AI verdict:
Trace Networks published as ArcGIS Enterprise services do NOT allow moving network features and non-network features together.
This is an Esri-imposed structural limitation, not a setting you can change.
Even if:
  • the Trace Network topology is disabled,
  • network features can be moved individually,
  • non-network features can be moved,
➡️ArcGIS Enterprise blocks multi-layer moves when a Trace Network feature class is involved.
Network features are treated as “protected” when coming from a feature service.
Why Esri enforces this restriction
Because in an Enterprise environment:
  • the Trace Network must maintain strict coherence
  • connectivity and topology validation happen server-side
  • ArcGIS Pro cannot “locally” manage a temporary state where a bulk move breaks connectivity
So:
➡️multi-layer moves = blocked
➡️single network-feature moves = permitted
I guess this is pretty similar for Utility Networks.
Best regards,
Charles
