Open Word document immediately when clicking a point (skip pop-up) — ArcGIS Pro 3.5.3
769
12-04-2025 09:37 AM
ReidiGjuzi
Hi everyone,
I’m using ArcGIS Pro 3.5.3 and have created a point layer by geocoding a CSV file containing addresses and a field with full file paths to local Word documents.
The pop-up is working correctly — when I click a point, the pop-up opens and the hyperlink inside successfully opens the correct Word document.
What I want to do is bypass the pop-up entirely.
My goal is:
Click a point → the Word document opens immediately, without needing to click the hyperlink inside the pop-up.
Additional details that may be relevant:
  • The documents are local files (e.g., C:\Folder\Subfolder\...).
  • The Hyperlink tool is grayed out, so I cannot enable standard hyperlink behavior on the layer.
  • Because the layer was originally created from a CSV and then exported/geocoded, I’m not sure whether this affects ArcGIS Pro’s hyperlink capabilities.
  • The pop-up and hyperlinks work correctly, but only when manually clicked inside the pop-up.
If anyone knows whether ArcGIS Pro supports automatically opening local documents when clicking a point, or if there is a different workflow or setting required, I would appreciate any guidance.
Thank you.
Tags (3)
RTPL_AU
Comment deleted - I missed the part saying links work when clicked.
DuncanHornby
MVP Notable Contributor
According to google:
It is not possible to use an ArcGIS Arcade expression to automatically open a hyperlink when a user clicks a feature in a web map. Security restrictions in web browsers and ArcGIS Online prevent the automatic execution of a hyperlink without a deliberate click on the link itself by the user.
Although this talks about AGOL I would imagine this applies to ArcPro as that's where you typically configure a pop-up.
A solution would be to create an add-in with a button that uses the sdk to listen for an onclick event and call the appropriate code for opening a word document. This would require you to get a GIS developer to create the custom code for you.
