Modify Features: Traverse doesn't make feature
550
07-22-2025 08:43 AM
ThomasGoodridge
I've been drawing easements, and every time I use the Traverse tool it draws the easement and then deletes it when I click the green checkmark. If it doesn't delete it, it leaves a shape that can't be edited and doesn't show up in the attribute table.
CodyPatterson
MVP Regular Contributor
Hey @ThomasGoodridge
What version of ArcPro are you using?
Also, I'm wondering if this could be a layer filter on the map itself or a definition query that's preventing these from showing? I'd check those places first in my mind.
Cody
ThomasGoodridge
There are no definition queries, and the layer is on. If I draw the easement manually, then it will create it just fine. The traverse easement stays there long enough that I can trace over it with Create Features.
