Modify data type fields in table
1028
06-05-2024 09:39 AM
JuanParra
I am trying to map and build a line between two reference points on a ARC GIS PRO map. There is a function called “XY to Line” that helps me to do that. I have a Excel spreadsheet as my data source that has the two sets of geospatial reference points (Start and End Xs and Ys). I have added this data layer (excel) to Arc GIS PRO project/map. It is a large file (100,000 waste transfers). I called the XY to Line function. Okay I am able to enter the Start X and Y points (Columns named 67# Latitude  and 68# Latitude) since they are formatted as “double” numeric types. However, I believe that ARC GIS PRO is not recognizing my second set of georeferenced points as X and Y End points because it believes they are “text” fields. I do not know how to change the data type in ARC GIS PRO. Thanks
Tags (1)
DanPatterson
MVP Esteemed Contributor
fix your excel file so that the field names don't have punctuation or spaces ( underscore is fine though)
then use
Excel To Table (Conversion)—ArcGIS Pro | Documentation
and use a geodatabase table and confirm that all the geometry fields are indeed numeric,
if they aren't, go back to excel and make it so
... sort of retired...
