Modelbuilder extent parameter gives Error 000800 even though the value IS a listed.
840
10-26-2023 05:58 AM
jbcypreste
Trying to run a contour line layer through modelbuilder (topo to raster), but when I select the source layer as parameter, it gives error 000800, claiming "ELEVATION" field is not accepted, even though it's part of the fields (OBJECTID, ELEVATION and shape_length are the only fields.
This only happens if I run the topo to raster through modelbuilder, if I use the tool by itself it runs fine.
dcaESRIwvges
it looks like this may be long done, but I'm hoping this will bring someone who knows to this thread. I'm having the same issues with a value list filter. I have set the values in each list but when i go to select a value and run the tool it gives me a red X and says:
"Error 000800 The value is not a member of..." then it lists all the values in the list. i'm using the values in the list to pick one of them with the dropdown but it doesn't recognize the value as a member of the list... insane.
