Modelbuilder Apply symbology to layer not applying
1624
04-25-2022 10:16 AM
BrandonLewis2
I'm creating a tool, if I make it the exact way in ArcMap it works fine. In ArcPro 2.9 it doesn't work.
Im trying to Apply symbology to layer.  Each day there is a different shape file input, so the input file needs to be a Parameter that is chosen from the current map.
If I am viewing the map and run the tool from Catalog, it prompts me to select the Layer input.  It runs with no errors but accomplishes nothing.  If I run it from the ModelBuilder screen it says: "None of the processes are ready to run."
圈圈
你似乎还没有设置输入图层,在模型构建器中,它是灰色的
