Model Builder
978
04-14-2025 01:22 PM
Labels (3)
ShamsunNahar
I defined a parameter in ModelBuilder, but it's not appearing in the Geoprocessing tab. I also tried setting it through the model's properties, but that didn't work either. How can I make the parameter show up in the Geoprocessing tab?
DavidSolari
MVP Regular Contributor
There's no parameter in your screenshot, just the headers of the empty table. You can make any variable a parameter by right-clicking on it and ticking the option. They'll have a "P" next to their symbol if they're a parameter
DanPatterson
MVP Esteemed Contributor
As exemplified in the help topic on Model Parameters
Model parameters—ArcGIS Pro | Documentation
P  Is what you will see in your model, set them according to the help topic.
To set a model variable as a parameter, the model must be edited in ModelBuilder. In ModelBuilder, right-click the variable and select Parameter. When a variable is set as a parameter, the letter P appears next to the variable in the model.
... sort of retired...
