Model Builder User-Created String Parameter into Output Feature Class Name
1564
12-13-2023 01:28 PM
Labels (2)
Henry
I'm still getting used to some of the changes to ArcGIS Pro's model builder - including the planned deprecation of the Feature Class to Feature Class tool in favor of the Export Features tool.
With Feature Class to Feature, it was really easy to define the Output Name for the Feature Class using a Parameter, as the tool had a defined Output Name value that could point to a user-input variable.
Is there a simple way to establish the same? I want to have the user input a string that would then be used as a parameter for the Feature Class name in the Export Features tool.
Thank you
Henry
DavidPike
MVP Notable Contributor
Can you not just put the argument into the output path?
RyanBohan
The new Export Features tool removes a major functionality of the Feature Class to Feature Class.  The ability to use a model variable for the Output Name is highly useful to add in a timestamp to the output.  I have suggested this idea as an idea Match previous functionality of Export Features to... - Esri Community
