Model Builder, Select by Attribute using in-line variable from different table
1469
05-28-2019 01:38 PM
JasonRogers1
I have two datasets, both with a Date field. For brevity sake, let's call them "Master_FL" and "New_Features".
In model builder, I want to Select by Attribute from the "Master_FL" using a query of 'On or After', with the variable being the earliest date from "New_Features" layer.
How do I do this in ArcGIS Pro 2.2?  Thank you for the assistance.
KoryKramer
Esri Community Moderator
JasonRogers1
Still need help with this.
What is the syntax for using a date in the SQL query for the “Select By Attribute” tool?
