Model Builder Error 000271 - Cannot use existing layers
492
12-01-2024 12:18 PM
Rick_O_Hara
I have some simple point layers that I'm trying to incorporate into a model. Why would my layers suddenly not work? The layers are fine. It doesn't matter where they are; if I drag them over from the catalog pane, they won't work either. I'm always struggling to get any tool to work from day to day.
Thanks.
DanPatterson
MVP Esteemed Contributor
Add and connect data and tools and modify elements—ArcGIS Pro | Documentation
add map layers from map contents pane
add featureclasses from catalog pane
And are the point layers featureclasses in a local file geodatabase or some other incarnation of a point layer or are they added to the map from some other location.source?
... sort of retired...
Rick_O_Hara
Thanks @DanPatterson.
They are in a file geodatabase.
I just shut it off and on and started a new model. It was just an esri thing.
