Merging Multiple Line Segments Within Spatial Constraints
2125
02-15-2022 12:14 PM
AarushiJhatro
Hello Everyone,
I have a line shapefile that I created using supervised image classification, with the purpose of delineating vine rows in a vineyard. The classification worked to an extent, and gave me multiple line segments per vine row (as seen in the image below).
I am now stuck on how to connect these segments to other segments in a row. Is it possible to automate this and not have to manually connect all the lines? I tried using topology, and 'no dangles' rule, and tried to snap a line end point to another within a given distance. Unfortunately, often this results in a line segment snapping to a line segment in the next row instead of snapping to a segment in the same row.
Would really appreciate any solutions/guidance on how to work around this.
Thank you!
Best,
Aarushi
DanPatterson
MVP Esteemed Contributor
You could give
Extend Line (Editing)—ArcGIS Pro | Documentation
a try... on a copy of your data
... sort of retired...
AarushiJhatro
Thank you Dan! This certainly works in connecting the segments. While the extended and connected segments don't make straight lines, using Extend Line has brought me one step closer to having vineyard rows representing lines.
DanPatterson
glad it is working... and who says vines need to be planted perfectly straight.... but if you do
How Simplify Line and Simplify Polygon work—ArcGIS Pro | Documentation
might go a ways to smooth things out
AarushiJhatro
Thank you...for helping me connect the dots!
