Merging 4 tables into 1
2781
08-24-2023 08:02 AM
AndrewReynoldsDevon
As the output of a model I have 4 tables with the same headings which I want to merge into 1 table. In Excel this is easy as you just add a new row but in Pro the merge tool only returns one value. I need a table with 4 rows in it. Each table only has 1 row of data so it needs to take each row & then add it on as a new row in the table.
Thanks
Andy
DanPatterson
MVP Esteemed Contributor
Append (Data Management)—ArcGIS Pro | Documentation
doesn't work?
... sort of retired...
AndrewReynoldsDevon
I tried to use the Append tool however you get the same row repeated 4 times when I need unique data on each row. Each one of the 4 source tables contains a row of data that I want to combine into 1 table with 4 rows
AndrewReynoldsDevon
I have a model that is run 4 times where it creates a row of data each time it's run however I need it add a new row for each time the model is run
AndrewReynoldsDevon
The append tool 'Merge rules allow you to specify how values from two or more input fields will be merged or combined into a single output value. The following merge rules can be used to determine how the output field will be populated with values:'. I don't want  1 output I need 4
AndrewReynoldsDevon
I need to carry out an upsert operation which you can do with the Append tool in Pro 3.1 but I have 2.8
