merge not working
7368
05-16-2019 07:59 AM
deleted-user-K9U1SzFzl3f7
To confirm the tool is having an issue, I went ahead and copied a shapefile and deleted all the fields in the copied shapefile. I then used merge with the original copied file and get a new file without any fields whatsoever.
This is with a point shapefile. Polygon shapefiles work with merge.
 WARNING 000594: Input feature 0: falls outside of output geometry domains.
The original file was created using AutoCAD and exported to shape.
using arcpro 2.2.0 maybe I'll upgrade
KoryKramer
Esri Community Moderator
KoryKramer
MichaelVolz
Esteemed Contributor
The bug seems to apply to ArcMap, but the enduser says they are using Pro.  Is the documentation not thorough enough as it leaves out whether this bug also occurs in Pro?
KoryKramer
Most of the gp tools and errors are the same between Pro and ArcMap.  For something like this, it would seem that the geometry error described in the technical article might address what Brandon McLaughlin‌ is experiencing.  Brandon, what say you?
Hi guys, thanks for your replies. This was such an easy work around and I'm thankful the technical bulletin solved the problem with ease. I went with option #2 and disabled M and Z values in environments, and the tool operated as intended.
KoryKramer
Great!  Glad that worked out.
