Merge multiple features and keep all attributes?
7224
09-29-2022 09:19 AM
avonmoos
When I run a merge to combine 4 polygon features it is only keeping the attributes from the first feature selected in the merge tool and leaving the rest of the attributes as null for the remaining 3 features. How do I combine all of my features into a single feature and keep their attribute data?
Robert_LeClair
Esri Esteemed Contributor
If you're using the Merge command in the Modify Features pane, using default behavior this is expected.  But if you slightly change your workflow to create a new feature with the Merge command and choose to preserve their attributes, you can.  See the documentation here for the correct workflow.
Robert_LeClair
avonmoos
I'll take a look and test it out. Thanks for the info.
