Merge/Join multiple layers and use layer name as new field name for RASTERVALU
1855
01-22-2024 08:05 AM
BenBlowers2
Hello
I would like to merge over 100 layers into a single layer, and use the layer name from each layer as a new field name with the attributes pulled across.
For example the final table might look something like this
Does anyone know how to do this?
Ben
Robert_LeClair
Esri Esteemed Contributor
I believe the Merge (Data Management) GP tool using the Field Map parameter to add fields to the output attribute table would be your best approach.
