Maximum pixel size using deep learning
1829
10-26-2021 12:42 AM
Zaki
Hi, how much is the maximum pixel-size on the images i use to do deep learning analysis in ArcGIS PRO?
I remember that i saw a video which said something about 30cm, does someone have the link to that video?
DanPatterson
MVP Esteemed Contributor
for what activity?
Building footprint extraction? 10-40 cm  Deep Learning with ArcGIS Pro Tips & Tricks: Part 2 (esri.com)
... sort of retired...
DrVSSKiran
It depends on your image resolution and the type of object which you wish
to detect.
For example.
If I want to detect a car or tree or road crosswalks I want 20 to 30 cm
pixel size. On another side, If I want to detect forest patches, land
parcels, or settlement clusters I can use 50 cm to 1-meter resolution.
Similarly, If you are working on Land Use and Land Cover you can work 30 cm
to 10-meter resolution. Even you can use deep learning on sentinel
datasets. Hope I answered your question.
Thanks
DanPatterson
for what activity?
Zaki
Hi, it is building footprint extraction. Your reply answers the question perfectly 🙂
