What video card and spec are you using? and have you updated with the most recent drivers from the manufacturer ? (not windows update)
Nvidia Quadro K2200
Just updated to latest driver (version: 9.18.13.4752)
Everything worked fine in 2.2
ArcGIS Pro 2.3 system requirements—ArcGIS Pro | ArcGIS Desktop
has the video specs as well, which have changed, perhaps the two starred considerations should be looked at there.
Thanks Dan. Unfortunately, I don't know what how to check those specs against my computer.
I'll try and contact customer service.
Will give you a basic check.
Start Button, type System... your system spec in geek-speak is listed there.
Thanks, Company blocks Can You Run It? Reads it as spyware.
