Maps are glitchy when zooming in and out of 2d map
1459
6
02-04-2019 09:55 AM
BrianE1
When zooming in and out on 2d maps Pro takes a few seconds to show the map. White tiling occurs (see attached screenshot).
I mentioned this in beta testing but apparently wasn't fixed.
DanPatterson_Retired
What video card and spec are you using? and have you updated with the most recent drivers from the manufacturer ? (not windows update)
BrianE1
Nvidia Quadro K2200
Just updated to latest driver (version: 9.18.13.4752)
Everything worked fine in 2.2
ArcGIS Pro 2.3 system requirements—ArcGIS Pro | ArcGIS Desktop
has the video specs as well, which have changed, perhaps the two starred considerations should be looked at there.
BrianE1
Thanks Dan. Unfortunately, I don't know what how to check those specs against my computer.
I'll try and contact customer service.
Can You Run It?
Will give you a basic check.
Start Button, type System... your system spec in geek-speak is listed there.
BrianE1
Thanks, Company blocks Can You Run It? Reads it as spyware.
