Map grid for 3D Map
993
04-06-2025 06:13 AM
ajakbar1999
I wonder if it's possible to create grid for my 3d map in local scene just like a picture generated in this link. Because unlike in 2d map the grid option in insert table isn't available. anyone has suggestion?
https://mapasgeologicos.blogspot.com/2016/06/12-bloque-3d.html
Andrew--Johnson
Check out this blog which hopefully is what you are looking for https://www.esri.com/arcgis-blog/products/arcgis-pro/mapping/how-to-make-this-3d-diorama-of-the-stra...
thanks,
Andrew
ajakbar1999
Hi, andrew. Thanks for the response. I already follow this blog for reference. However, I got stuck in the grid label. What I need is a grid label like in this figure https://community.esri.com/t5/arcgis-pro-questions/3d-vertical-grid-not-showing/td-p/1040401?lightbo...
In the figure there is a grid label under the ERT profile. Please let me know if you know any blog talk on this.
