Make Table View Tool and Displaying Geometry Points
7117
10
09-01-2021 12:02 PM
ChuckBenton
I need to create a table that explicitly displays the points that define a polygon boundary. Make Table View comes close, but the Shape field simply displays "Polygon". Is there a tool which outputs a list of points for each polygon?
Chuck
ChuckBenton
So it was curves that was the issue. Besides that all is well. thanks for the help!!!
Chuck
DanPatterson
MVP Esteemed Contributor
You have to convert it a point file to get the point values
Feature Vertices To Points (Data Management)—ArcGIS Pro | Documentation
Then you can use the field calculator or
Add Geometry Attributes (Data Management)—ArcGIS Pro | Documentation or
Add XY Coordinates (Data Management)—ArcGIS Pro | Documentation
to add the coordinates to the table
... sort of retired...
ChuckBenton
Thanks Dan.  Headed out momentarily and will try this in the AM. I suspect the geometry details (such as multiple polygons in a parcel) get lost... looking to generate something like:
Longitude
Latitude
Geometry
-89.0259
38.09963
POLYGON ((-89.0237086 38.1015136, -89.0234627 38.0976878, -89.0235319 38.097689, -89.028015 38.0977517, -89.0280308 38.0977518, -89.0283478 38.1015333, -89.0237929 38.101514, -89.0237781 38.1015139, -89.0237086 38.1015136))
-89.023917
38.120071
MULTIPOLYGON (((-89.0231767 38.1177508, -89.0237414 38.1164201, -89.0247357 38.1164507, -89.0247523 38.1164509, -89.0248053 38.1164514, -89.0248041 38.1177957, -89.0247511 38.117794, -89.0247345 38.1177935, -89.0231767 38.1177508)), ((-89.0231767 38.1177508, -89.0231754 38.1191253, -89.0247331 38.1191616, -89.0247498 38.1191621, -89.0248028 38.1191635, -89.0248013 38.1199945, -89.0248007 38.1200951, -89.0247478 38.1200951, -89.0247315 38.1200952, -89.0247314 38.1200952, -89.0222174 38.1200228, -89.0231767 38.1177508)))
Any Suggestions?
DanPatterson
Ugly but doable
ChuckBenton
Interesting. I don't recognize the screen you captured... from Pro?
ChuckBenton
I found it... ignore the previous. That said, I take my selected area, create a new field called GEOMETRY, run the calculate field, and get (null) results. Ideas?
DanPatterson
little s not S look carefully at my expression... case-sensitivity... I typed and didn't select the "Shape" from the list... learned the hard way 😉
ChuckBenton
I'd done the small 's'  first... same result...
Not sure what to make of it...
DanPatterson
No clue why yours isn't working...
  • polygon featureclass in a file geodatabase (so network-thing or web-thing)
    • simple polygons, no curves or circles....
      • maybe WKT doesn't handle curves well... densify the fc if you do)
  • Text field... WKT field name (maybe GEOMETRY isn't a good field name)
  • do the field calculation watching for the small 's'
See the image.
Alternatives that I normally use... TableToNumPyArray with "explode to points", reassemble the table geometry in NumPy and export to another format
ChuckBenton
Chuck
