Make Route Event Layer problem in ArcGIS Pro 3.0.2
1496
11-17-2022 03:21 PM
Labels (2)
EadieKaltenbacher
Hello, I built a model that was working just fine in ArcGIS Pro 2.0. I have upgraded to 3.0.2 and now many of my tools in my model are broken. I am rebuilding it step by step and have come across the Make Route Event Layer tool.
The tool will not accept any values in the Route Identifier Field, as indicated by a red X and failing when I run the model. I get the same error trying to perform this task directly from the toolbox. The field I want to use is a Long Integer, and again, it worked just fine in the last version. Any ideas?
Big picture: this is one step in a large model that identifies polygons to the left of this line. Any other workarounds to achieve this solution appreciated too.
EadieKaltenbacher
I couldn't resolve this problem and ended up reverting back to ArcGIS Pro 2.9, my models are now working again.
