Make Feature Layer within a model does not add the layer
10367
20
05-13-2021 01:15 PM
RandyMcGregor3
If I run Make Feature Layer as a tool, the new layer is added to my map. If I put the tool in a model and run the model ('Add to Display' is selected), The layer never appears.
If I open the model and run it, the layer is added to the map, but they are in an awkward group called 'ModelBuilder' and have a prefix I don't want them to have.
I would like to run the model as a tool and when I do that, nothing gets added to the map.
Is there something I can do to make the created layers visible?
Thank you,
Randy McGregor
RandyMcGregor3
FWIW - I think ESRI (Hi ESRI!) should change 'Solved! See solution.' to, 'Answered! See answer.'
