Lists in Arcade
10488
07-17-2020 11:08 AM
JoeBorgione
When constructing a list in a python script, it's easy to accommodate long entries to make them readable by splitting them into several lines:
myList = ['blahblah0', 'blahblah1', 'blahblah2',
          'blahblah3', 'blahblah4', 'blahblah5']‍‍
However, the same does not hold true in arcade.  I have to construct a list of attributes that goes on ad nauseam for an attribute rule .  Adding attribute field names in an arcade list that goes on seemingly forever is tedious at best.  Is there a way to manage a list such that arcade can be happy with it and I don't go blind?  Can I merge a series of lists together in arcade?  That way I could have multiple lists each of a readable size, and merge them into one 'one the fly' so arcade can read each of the attributes?
Xander Bakker
Chris Fox
That should just about do it....
Tags (1)
XanderBakker
Esri Esteemed Contributor
Hi Joe Borgione ,
In Arcade you can also split long lists over multiple lines:
var myList = ['blahblah0', 'blahblah1', 'blahblah2',
              'blahblah3', 'blahblah4', 'blahblah5'];
To combine multiple list you don't have the easy sum of the lists as you have in Python but you can do this:
var lst1 = ['blahblah0', 'blahblah1', 'blahblah2'];
var lst2 = ['blahblah3', 'blahblah4', 'blahblah5'];
var lst = lst1;
for (var i in lst2) {
    lst[Count(lst)] = lst2[i];
return lst;
...or even this (which will not work for lists with numeric data):
var lst  = Split(Concatenate(lst1, "#") + "#" + Concatenate(lst2, "#"), "#");
return lst;
XanderBakker
Hi Joe Borgione ,
var lst = lst1;
return lst;
return lst;
JoeBorgione
So all it takes is a semi colon and I'm good to go?  Awesome!  Thanks Xander Bakkerr!
XanderBakker
Hi jborgion
I don't think the semicolon is required. The "var " at the beginning is.
