Limited panning after Edit Query Layer
593
08-24-2023 01:25 PM
BryanSchaefer
Good day.
After completing a project I thought I'd, let's say, be efficient and use that project to start another. The project uses the same layers, symbols, zooms, etc. the only difference is the table. The table has the same data, data types, and number of columns.
I did a Save As and processed to change each layer Source/Query by right-clicking the layer, selecting Properties, selecting Query, and then changing the Name of the Table in the Edit Query Layer window. The features were successfully updated, however, the features moved off the map. I can zoom out and locate them again. But when zooming and panning to center the features again they zoom off screen or I can only pan in the Map window a limited amount (can not pan the features to the bottom of the window for example) before the features, again, move off-screen.
Any thoughts on how I can correct this? Or is Save As out as an option in ArcMap 2.*
Thank you.
