Limitations on creating a very large tile package?
1856
12-22-2020 07:57 AM
Ken_Doman
I'm working through the workflow of creating a very large tile package to upload to ArcGIS Online as a hosted tile layer. I've created the 344GB tile cache on a 1.02 TB drive, and I'm working through the process of Exporting the Tile Cache to a tile package (.tpkx) file. I've successfully generated an almost 4 GB tile package with a subset of the map scales and uploaded it to ArcGIS Online without a problem. When I run the Export Tile Cache on all scales, it gives me a success notification after 12 hours, but the tile package file is only 10KB, and doesn't show anything when uploaded to ArcGIS Online.
Is there a limitation on creating very large tile packages?
  • Is there a maximum size for a tile package file?
  • How much space is required to generate a tile package?
  • If so, can a hosted tile service have tiles generated from multiple tile packages?
I'm currently running ArcGIS Pro 2.4 on a virtual Windows Server, and an update to 2.7 is pending a server restart during off hours.
Darko_Petrovic
Ive just come across this post. I had a similar issue when trying to publish a large tile cache using DroneDeploy imagery.
Using Fiddler to review error messages from ArcGIS Pro, we found that ArcGIS Online has a limit on the number of bundles (i.e. tile collections) it can publish in one tile cache. This could be hte issue that you are encountering.
Darko
