Limit the zoom range of a map?
1437
09-23-2021 07:50 AM
dstrigl
Is there a possibility to limit the range of zooming of a map in ArcGIS Pro (or when using it inside a dashboard)?
Regards,
Daniel.
Tags (3)
RobertBorchert
Honored Contributor
I think the best you can do is set a Custom Extent.  It will still allow you to zoom out past a certain extent but you can get back to the custom extent.
Maybe you can play with limiting visible extent for smaller features. I know if I have all my features turned and I scroll out to far performance gets down.  So changing the visible scale for smaller features helps.
In AGOL you can set a custom extent for your organization.
dstrigl
Hi @RobertBorchert,
thanks for your fast answer. I allready set a "Custom Extend" for my map, but this doesn't not prevent the user to zoom into the map (too much).
Of course, I can define the "Visibility Range" for each layer in my map, to prevent displaying it in some zoom levels ...
But I would like, that it's only possible for a user of the map and/or dasboard to zoom in a defined range!
Regards,
Daniel.
