Legend Formatting in ArcGIS Pro
8509
07-12-2016 09:37 AM
RobertRose
I am trying to format a legend in ArcPro and not sure how to get it to look the way I would like.  I prefer a legend to list polygon/raster layers first, the lines, then points.  In ArcGIS Desktop, it is really easy to order items in the legend using this hierarchy, but  in ArcGIS Pro, this does not seem possible without reordering the items in the table of contents, which reorders them in my map, rendering points and lines invisible if they fall below a polygon or raster.  Any suggestions?
DanPatterson_Retired
I would check this link Add a legend—Layouts | ArcGIS for Desktop
and the links below to ensure that there isn't some toggle disabling the add legend elements in the TOC order
MervynLotter
MVP Regular Contributor
Hi Rob
It is possible to just click and drag items under the Legend list. You may
need to click on the side triangle to expand the list, or the Legend may be
locked (clicking on the lock symbol either opens or locks the legend
items). In my example below, I could easily drag items and that changed
the order in the legend display.
Regards
Mervyn
SarahHartholt
is it possible to reorder items that are displayed using unique values without changing their drawing order?
RobertRose
Thanks All.  I have found how to reorder the legend under the Legend Drawing order.
