Layers Don't Render Completely in ArcGIS Pro
3085
6
04-05-2022 07:06 AM
by Anonymous User
Not applicable
My layers often fail to draw completely or partially. I have received no error messages about cache capacity. I've tried clearing the cache in Display settings and that did nothing. This has happened to me in multiple projects, not just in one.
Here's a screenshot of the partially drawn layers. Most of the blue should be covered by grey or white polygons:
Tags (1)
Robert_LeClair
Esri Esteemed Contributor
Okay - another option is to export the shapefile to a file geodatabase feature class instead of using a shapefile.  Is there a difference?
George_Thompson
Esri Notable Contributor
Where is the source data coming from: Enterprise Geodatabase, Feature / Map Service, etc.?
--- George T.
by Anonymous User
Not applicable
Hi George,
I'm working in a remote desktop and I'm pulling the data from a drive accessed through the remote desktop (see below for what the path looks like). Don't have an Enterprise Geodatabase. Thanks for your help!
Robert_LeClair
I'd recommend trying the Repair Geometry GP tool on your shapefile, then using the newly output feature class (either shapefile or geodatabase feature class), turn off the original one and turn on the new one.  What is the result?
by Anonymous User
Not applicable
I just ran Repair Geometry on two of the layers that aren't rendering correctly, and it added one of the missing country polygons but that seems to be it:
Robert_LeClair
by Anonymous User
Not applicable
This solved the issue, thanks so much!
