Labels for Quantile classes
3321
7
08-31-2022 09:37 AM
Craig_Eissler_Iceman
Hello, please see example below:
If I wanted to replace the Label column with "percentages", what would those values be?
(Obviously, each class contains 25% of the data since these are Quantiles)
But I am not certain what the correct ways are to express the percentage (as a label) for each class?
Thanks!
DanPatterson
MVP Esteemed Contributor
<= 25%
>25 - <= 50%
>50 - <= 75%
> 75%
If you want to get real picky you would need to know what the exact values of the quantile boundaries are and adjust the <= or < symbology.  It follows the upper value symbology
... sort of retired...
OK thanks Dan, but "reversed" in association with the graphic I provided..?
Also, what about using (adding) words like "Top" or "Middle" or "Bottom", etc?
DanPatterson
Yes.  I wouldn't add those words since they often have different terms discipline dependent.
Quartile - Wikipedia
In reading that Wiki, it seems to be naming the break values -- which there are 3; and not the classes (value ranges) -- which there are 4 ...is that correct? If so, then it doesn't seem like that naming structure is a match.
I'm still looking for "words" to add to the numerical values (percentages) if it's an option..? Then I will elaborate in writing in my report for clarification.
...In other words, would something like this  still be correct?
> 75% (Top 25%)
>50 - <= 75% (Top-Middle 25%)
>25 - <= 50% (Bottom-Middle 25%)
<= 25% (Bottom 25%)
...that said, if you had 5 classes (Quintiles) could you label just the Top 20%, Middle 20%, and Bottom 20%, and just leave the two in-between classes not labeled, or just with the numerical values?
DanPatterson
As I indicated, the useage is discipline specific,
For instance I would report the median value and the upper bounds of the inter-quartile range as Q1, Q2 and Q3.  But I taught statistics for a number of years so it may not be useful for someone with less jargon baggage.
Thanks for your suggestions, and in some cases, I can see that would be most appropriate.
However, I'm not certain it would be for my audience. So, aside from "appropriateness", I guess I'm still wondering if my suggestions would at least be "accurate" ...can this be answered with a yes or no?
Thanks 🙂
