Labels disappear at certain (larger) scales
5179
12-01-2022 05:26 PM
Craig_Eissler_Iceman
Hello, see map below, where two county labels disappear at certain (larger) scales ...as I zoom in, in other words. I realize that it's probably because those two counties are narrow, so the label doesn't fit.
But, how can I control this so that they stay put?
Thanks, CCE
Tags (1)
JohannesLindner
The ArcGIS Pro label engine has a huge amount of options for placing and fitting labels and for conflict resolution.
Take a look at the docs: Label with the Maplex Label Engine—ArcGIS Pro | Documentation
Some solutions for your problem:
  • Use straight label placement instead of horizontal:
  • Don't try to place the labels at fixed positions:
  • Play with the Overrun and Reduce Size parameters
  • Just force all labels to appear
Have a great day!
Johannes
JohannesLindner
Have a great day!
Johannes
Great suggestions, Johannes -- 2 out of those 4 did the trick!
I have a few tiny islands just off the south coast that are part of counties on the main island. So, some options attempt to label those as well, but those are unnecessary.
Thanks again!
