Labeling on ArcGIS Pro
3516
08-29-2021 02:14 AM
PamelaGill
I would like to create 2 labels that go together but are formatting differently. One would be a number placed within a circle and the other would be text sitting beside this.  The way I have currently created the numeric label is to sit it on top of a point that sits adjacent to the polygon on the map.  This is not ideal but I couldn't think how else to do this.  Appreciate any ideas you may have.
Tags (1)
2 Solutions
David_Brooks
MVP Regular Contributor
You may have already thought about this, and there may be a more elegant approach, but you could just duplicate your layer, set the symbology to clear/nothing and label that with the 2nd style?
David
..Maps with no limits..
PamelaGill
Yes, I did think of this after asking the question!  Thanks for the response though.
David_Brooks
David
PamelaGill
DanPatterson
MVP Esteemed Contributor
Would a composite callout be appropriate for your labels?
Label using a composite callout—ArcGIS Pro | Documentation
... sort of retired...
PamelaGill
Thanks for this.  Interesting but not quite how I wanted it to look.
