Keeping attribute table active after panning
3111
9
03-05-2024 12:38 PM
celtics08
Currently using the 3.2.1 version and like the title says I'm looking for a way to keep the attribute table active after panning. I'm using the keyboard arrows then CTRL + N to pan. After panning, the map window becomes active (arrows nudge map). I want to be able to use arrows to just go to the next record so I can pan again. Is this possible? Thanks for any help.
KoryKramer
Esri Esteemed Contributor
@celtics08 we're adding an option for you to control this in ArcGIS Pro 3.3 (scheduled for May). It is in the Table options > Activate the map view after using Flash, Pan, or Zoom from the table.
That should give you what you're looking for.
Bud
Legendary Contributor
Does @KoryKramer know if there is a keyboard shortcut to give the attribute table focus?
Would you be able to show us a screen recording video using a program like ScreenToGIF? Enable keystroke display in the image tab and save the file as an .mp4.
celtics08
I can give that a try, but most likely can’t install on my work PC. I’ll check there’s something similar I can use. Thanks for the reply.
Bud
There is a portable version that doesn’t require windows admin privileges. I use it at work even though I can’t install programs.
celtics08
Thanks for the tip, I'll do that.
celtics08
Best way to post the mp4? I'm getting a message that says I don't have permission to post a video.
Bud
Maybe that’s because you’re a new member. Does a GIF work? You should be able to change the file type to GIF in ScreenToGIF in the Save As pane.
celtics08
Hope this helps visualize this issue, thanks for the tips so far, I really appreciate it.
KoryKramer
celtics08
Excellent news! Thank you for letting me know!
