Joins
1345
11-12-2021 08:51 AM
MansfieldGIS
I was wondering if this was possible to join 2 attribute tables from 2 different geodatabases.  I have a feature class in 1 geodatabase and another feature class in a different geodatabase.  I would like to join the attribute tabels.
MichaelVolz
Esteemed Contributor
Are you planning to use this join in a service used in a web app as I don't believe that workflow is supported?
by Anonymous User
Not applicable
If I were using ArcPRO I would add both databases (right click on databases, click add database) , then add to current map, and then join with a common field.
