Joining two polygons
1080
07-14-2022 06:49 PM
Mento
So, I have two shapefiles one consists of 32 large polygons (neighbourhoods), and another shapefile contains 283 smaller polygons (Dissamineation areas). I want to associate the neighbourhood names to the DA shapefile. I have a lot of DAs which are intersecting many neighbourhoods, so is there a way to join DA's where the majority of the DA polygon is in the neighbourhood. I tried using Spatial Join with the match option set to 'have their centre in' but was unsuccessful. I was only able to retrieve 24/32 neighbourhoods.
RichardHowe
Spatial Join is correct tool.
Target features should be the DA polygons
Join features should be your Neighbourhoods polygons
Join operation should be "One to one"
Match option should be "Largest overlap"
Erika_ess
Could you possibly create a topology before performing the spatial join?
