Join operation
1076
01-22-2021 05:33 PM
arcgisarcgipro_6
Hello I am having a trouble with join operation in Arcgis pro 2.7.0. I created two raster data with common columns which I executed join field by choosing them. They are both fine in different layers and seems no mistake. However after I joined those two tables the areas in the new map do not seem in the correct location when I chose Select by attiributes. I went through the same process twice but still cant figure out what is wrong. I would really appreciate if you help me. Thanks in advance.
DanPatterson
The raster table join would be on an attribute other object id I hope.
Check the example in this diagram in this link
Add Join (Data Management)—ArcGIS Pro | Documentation
... sort of retired...
