Geo-referencing an Obj 3D rendered Model to ArcGIS Pro
1405
01-22-2021 10:24 PM
SamiyaAl_Ismaily
I have a rendered (Obj) format model that I have imported to ArcGIS Pro using the tool “Import 3D Files”, but it is not located in the right position. I have tried Geo-referencing it but did not work. Then I used the multi-patched method: created a multipatch (simple cube or sphere) for the location where the .obj will be located. Then used the editing tool to replace the multipatch, the 3D got located but positioned upside down and the rotate icon takes time to rotate the object where the software (ArcGIS Pro) keeps loading and gets stuck.
I would appreciate it if someone can help to solve this issue.
Thank you
